Hello,
since today I am facing the issue that when pressing the Home button on the mount, the mount does not return to the correct Home Position any longer…
I had been doing an imaging session with the ASI Air yesterday night… everything had been working well and after the imaging session the mount had correctly slewed to Home Position as per Asi Air commands.
Today I was checking the collimation of my scope and slewed the scope to a couple of different positions manually with the Hand controller.
Then, when I finally tried to return the mount to Home Position with the Home button on the mount, it would not do so. It would rather remain in a position at around 9 o’clock. After hitting the Home button again, it would then continue to 4 o’clock (see pics attached), so its behavior seems a bit ramdom.
What is causing this issue, and how could I solve this?
Many thanks and kind regards
Roman
