TheSkyX OnStep X2 driver
For information, I have been helping Rodolphe Pineau adapt his X2 driver for OnStep to work with the WD mounts. After several changes, I think he has cracked it. This will allow one to connect to the mount via TheSkyX and make use of TPoint. For those using an imaging app that relies on ASCOM, like NINA, the ‘home’ function in NINA is not supported, but you can home the mount within the driver settings within TSX, or run a VBS script using ASCOM, before connecting via TSX.
