Port Closed error in NINA
At the end of a remote session, I am getting a port closed error in NINA. Like the Wd-20 cannot be connected to. this is common, 80% of days this happens. i power the mount on and off, power on off the Pegasus powerbox and other things. some days only a windows reboot (win11) will solve the issue. I have turned off power saving in windows and in the USB hub on the device manager. I am a bit at wits end.
Hi Howard,
This issue should be caused by USB serial device free in windows. as port connection crashed in NINA while windows may still stuck in using it. You can also try reboot the USB COM Serial device in Windows Device manager, to instead of rebooting the PC.
