The new Mount Tool 1.0b keeps generating a never ending stream of messages regarding the COM port no longer active when I disconnect the mount. They can’t be cleared as fast as they are being generated. Please fix so just one message is generated instead of a Desktop full.
Thanks for your feedback, from your description, the error message may due to Auto Fresh function enabled, you can stop the refreshing before disconnect the COM.
Our R&D team will also check possible solution for this.
How do you disable it. Most of the functions you show as enabled show the button highlighted in green. This button is not highlighted.
I found another issue. Under the Status tab, the UTC date, time, and offset as well as your latitude and longitude are displayed. It is showing my longitude as +110 instead of -110 thus displaying a time in China while the offset is -7. The ASCOM Hub displays the correct longitude and offset. The hand controller displays the correct UTC time. However if I go to the Date/Time setting in the hand controller, it displays the same thing as the mount tool.
