Kstar and warpdrive
good morning everyone last night I was trying to get kstar going with my equipment.The first primable I encountered was not being able to connect wi-fi with Eagle(Window 10), at which point I had a doubt.
With Kstars and a laptop with Linux installed or a iMac is it possible ? if so how ?
Why WiFi? If you are using the Eagle, you could try USB. WiFi has to be set on mount, it can only do either BT or WiFi. Many report the WiFi connection is less reliable than the BT one with mobile apps.
Hi I only know that since I’m in the mountains everything broke me.
From the Mac keyboard to the two power supplies (by Eagle and the portable dl power supply and then the backup battery)
Now I will have to buy a power supply and I don’t know which one to buy to feed the WD20 and then with the bearer to be able to make the rest work with KStar this is the reason for the question.
