I’m clearly missing some instructions on updating the mount firmware. A dialog box pops up with several settings, including chipsets and so on, of which I have no knowledge!
I think it would be great to share a guide, to avoid failure, or worse.
I have a WD20 with the later serial numbers 20012407xxx
I updated the FW successfully. I could not read the motor values - I guess as I had not run the motor access tool. Is that necessary?
