Clicking sound when mount slews
My WD-20 mount makes a “clicking” sound while slewing, particularly during the 90-degree movement for polar alignment. What could be causing this, and how can it be resolved?
Here is the video: https://youtu.be/sUXBYf_r0gw
I wonder if it is the AEB feature. Can you disable it? Does it click without anything mounted on it?
Please check to ensure that all knobs, screws, and connections are securely fastened, including those on the tripod. Sometimes, if any parts are slightly loose, it can cause friction between metal components, leading to creaking or squeaking sounds.
