Buon giorno , ho un problema con Sesto Senso 2 dopo essere passato alla piattaforma ASCOM 7 e con la montatura Warpastron, ho inserito i Devices uno alla volta ma non funziona.
La cosa che trovo strana è che con Play (programma della prima Luce simile a N.I.N.A.) il collegamento con Sesto senso viene trovato e mi ha fatto persino la calibrazione , mentre con N.I.N.A. nulla
Fino al prima del cambio di Mount funzionava tutto ok.
Avete qualche suggerimento?
The very last nightly of NINA has found a problem connecting to some devices. There is a discussion on the NINA Discord forum and on the ASCOM developers forum. Watch this space. You could try going back to the last NINA full release, rather than a beta.
here i am again now with NINA not as beta release as recommended.
Upgrading to WD20 firmware to 20.22 went very well , but unfortunately I bought a new focuser always sixth sense 2 , the problem remains the same , that is the program tells me that the focuser is constant mind in movimeto , the only program , because if I use another one everything ok .
I am aware that you do not have anything to do with it , but the whole thing happened after I bought the WD20.If it is helpful to you I post the comp file of the ASCOM drivers
I’m using latest nightly beta and it is working fine now with latest OnStep ASCOM driver. For the focuser, I would run the ASCOM ConformU utility and check it out. If it fails, I would first talk to Primaluce. If it passes, then post a question on the NINA discord channel in the hardware issues thread. A very helpful bunch of guys.
