Ciao Gustavo , ti scrivo perchè non riesco a configurare WD20 con Primaluce Eagle come invece sembra tu sia riuscito.Il mio problema è con i driver del sesto senso 2 che sembra vada in conflitto con la WP20 tu come hai risoltro ?
So, I updated to 20.22W (no issues) and also adjusted the AEB via the PC Tool (v1.0b).
I noticed that the PC tool return to home does return to home correctly (it seeks home, even after a long slew). I attempted the same in NINA but the issue persists (it does not seek home, but just overshoots and stops).
How did you get it to seek home in the PC Tool? Is there a setting in NINA?
I have been using NINA for several weeks now. As in our earlier discussion I do homing in stages:
Unpark, tracking on, wait 5s, home, tracking on, wait 5s, home. in the advanced sequencer. Seems to work every time. I don’t need the second homing, as I’m now parking at about Alt/Az 5/5 but I tested it from different positions and it always worked.
Please try this and let me know. I can then be assured I have it right in the manual.
After levelling the mount and the losmandy/vixen clamp in the home position, my initial slew puts the target in the centre third of my camera FOV.
I need it for polar aligning, not so much the sequencing portion. I don’t mind if at the end of the session, it’s not quite centered on home, but during polar alignment, being off by a few degrees when restarting is a PITA
If you use Polemaster or SharpCap Pro - why not use my utility. It homes and moves the mount in RA in 45 degree jumps.
I don’t, I use NINA.
